My piechart needs to be like a spherical one, rather than circular. I tried setting the opacity from Zero at the center to maximum at the circumference , but that didnt solve the purpose, Is there anyway I can accomplish this. Sample one is given as an attatchment
Georgi,
Thanks for your suggestion. As you have said, I changed the gradient to circular and set the opacity from Zero to 255. In addition also removed the border to give some sense of 3D. Its fine. But is there anyway I could get too close to achieving the 3D like chart
May be one possible suggestion is to set the property "Effects"-> "GradientEffect"->"Style"->"Circular". Please look at the attached screen shot. If you have any questions do not hesitate to ask me.
Regards
