245
UltraNumericEditor spinbutton does not show always
Although in following code I an setting SpinButtonDisplayStyle to show "Always", I do not see spin button in that cell unless I move over mouse over that cell.
Is there any way I can show it forever ?
Also I've set the width of the grid column to 15 but I do not see enough space for spin button and integer number. I have to manual expand the column.
Vaquar
           m_uNumericEditor = new UltraNumericEditor();
            m_uNumericEditor.SpinButtonDisplayStyle = Infragistics.Win.ButtonDisplayStyle.Always;
            m_uNumericEditor.DisplayStyle = Infragistics.Win.EmbeddableElementDisplayStyle.VisualStudio2005;
            m_uNumericEditor.NumericType = NumericType.Integer;
            m_uNumericEditor.MinValue = 1;
            m_uNumericEditor.MaxValue = 180;
            m_uNumericEditor.MaskInput = "nnn";
  • 469350
    Set ButtonDisplayStyle on the grid column to Always.
    Use the PerformAutoResize method on the column.
  • 53790
    . This is behavior if you set the property "SpinButtonDisplayStyle = OnMouseEnter". When you set the property "SpinButtonDisplayStyle = Aways" the buttons must be visible. Could you please tell me what is your component version?
    One possible suggestion is to set one of these properties, for example:
    m_uNumericEditor.Width = 50; or  m_uNumericEditor.AutoSize = true;
    Please if you have any questions do not hesitate to ask me
    Regards
