There is definately room to fit the entire name 'Ferguson' on that line, why is the ellipses being put there? It doesn't happen on 'Hedges' which is perplexing. What setting is causing this?
Try setting the TextRenderingMode to GDI
This did not work unfortunately.
But... I had set the font to Calibri, 9pt... if I removed this font setting the ellipses goes away even though the Font Size gets larger... I do want the smaller font size though
If the View property is set to 'List', try setting the UltraListView.ViewSettingsList.ColumnWidth property to -1, this automatically sizes the column to show all item text.
