We upgraded to infragistics 9.2.20092.2119 (from 6.2) and UltraDateTimeEditor dropdown doesn't look right.
The dropdown portion of ultradateTimeEditor (InboxDateTimePicker) does not pick the appearance from InboxDateTimePicker (grey background versus white background , Dark blue Caption header versus White.). Even the selected date looks different.
You can see this behavior in AppStylist. I have attached snapshots of UltraDateTimeEditor and InboxDateTimePicker.
Please let me know if there is a workaround for this. I hate to change all my UltraDateTimeEditor controls to UltraCalendarCombo.
Related Post:http://forums.labs.infragistics.com/readmessage?id=%3C243217fe$70211fbd$13a6ac@news.infragistics.com%3E&group=infragistics.products.netadvantage.windowsforms.wineditors
Thanks, I used DotNetMonthDropDown and DotNetMonthDropDownTitle UI Roles and was able to change the appearance of the ultradatetimeditor dropdown control.
I was in a impression that I need to change appearance of Inbox DateTimePicker to change the dropdown appearance of UltraDateTimeEditor as its contained within UltraDateTimeEditor.
Hey all,
Im using an UltraWinGrid with a DateColumn , when clicking the arrow the same type of calendar as yours is displayed.
I'd like to remove Saturdays and Sunday on this calendar but I don't have a direct access to a calendar object .
How can I customize this calendar ?
Thank you
Vianney
I'm confused. :)
There are two different objects here. One is the MonthCalendar control which is included in the DotNet Framework. To style this control, you have to use the MonthCalendar Control Role as I described above.
The dropdown for the UltraDateTimeEditor dropdown is separate. This happens to be using the same control internally, but since it's contained within the UltraDateTeimeEditor, the UltraDateTimeEditor can handle styling it with some UI Roles. In this case, the EditorControl role is already being applied to the dropdown. You can also use the DotNetMonthCalendar UI Role to alter the appearance of this dropdown.
Both. the editor control in AppStylist does not have ANY effect after changing inbox DateTimePicker.
I can see my changes in Inbox DateTimePicker. If there a hot fix out for this release? I am using 9.2.20092.2119
Are you saying this is not working in your application, or it's not working in AppStylist? I tested this out in AppStylist before I posted my reply and it worked just fine for me.
