245
Derived UltraWinGrid loses appearance settings.
I am creating my own ultrawingrid control that inherits ultrawingrid and I want to apply apearance settings without manually going through some dialog gui to do it. I have set appearance settings in the constructor of the control but they are getting reset every time the control is dragged from the toolbox to the form, how can I keep the appearance settings I set in the code without them being reset?
Carl.
here is my example:
    public class Grid : UltraGrid
 public Grid()
            gridAppearance.BackColor = System.Drawing.Color.White;
            DisplayLayout.Appearance = gridAppearance;
            DisplayLayout.AutoFitStyle = Infragistics.Win.UltraWinGrid.AutoFitStyle.ResizeAllColumns;
            ultraGridColumnIsDirty.Header.VisiblePosition = 0;
            ultraGridColumnIsDirty.Width = 27;
            ultraGridColumnOnline.Header.VisiblePosition = 1;
            ultraGridColumnOnline.Width = 113;
            ultraGridColumnLastModified.Header.VisiblePosition = 2;
            ultraGridColumnLastModified.Width = 465;
            ultraGridBandDefaultBand.Columns.AddRange(new object[] {
            ultraGridColumnIsDirty,
            ultraGridColumnOnline,
            ultraGridColumnLastModified });
            ultraGridBandDefaultBand.Override.AllowRowSummaries = Infragistics.Win.UltraWinGrid.AllowRowSummaries.False;
            ultraGridBandDefaultBand.Override.GroupBySummaryDisplayStyle = Infragistics.Win.UltraWinGrid.GroupBySummaryDisplayStyle.SummaryCells;
            ultraGridBandDefaultBand.Override.SummaryDisplayArea = Infragistics.Win.UltraWinGrid.SummaryDisplayAreas.InGroupByRows;
            DisplayLayout.BandsSerializer.Add(ultraGridBandDefaultBand);
            DisplayLayout.BorderStyle = Infragistics.Win.UIElementBorderStyle.None;
            groupByBoxAppearance.FontData.Name = "Microsoft Sans Serif";
            groupByBoxAppearance.FontData.SizeInPoints = 10F;
            groupByBoxAppearance.ForeColor = System.Drawing.Color.Black;
            groupByBoxAppearance.ImageBackgroundStyle = Infragistics.Win.ImageBackgroundStyle.Stretched;
            DisplayLayout.GroupByBox.Appearance = groupByBoxAppearance;
            bandLabelAppearance.ForeColor = System.Drawing.Color.Black;
            DisplayLayout.GroupByBox.BandLabelAppearance = bandLabelAppearance;
            DisplayLayout.GroupByBox.ButtonConnectorStyle = Infragistics.Win.UIElementBorderStyle.WindowsVista;
            DisplayLayout.MaxColScrollRegions = 1;
            DisplayLayout.MaxRowScrollRegions = 1;
            DisplayLayout.Override.AllowAddNew = Infragistics.Win.UltraWinGrid.AllowAddNew.No;
            DisplayLayout.Override.AllowDelete = Infragistics.Win.DefaultableBoolean.False;
            DisplayLayout.Override.AllowRowSummaries = Infragistics.Win.UltraWinGrid.AllowRowSummaries.False;
            DisplayLayout.Override.AllowUpdate = Infragistics.Win.DefaultableBoolean.True;
            DisplayLayout.Override.BorderStyleCell = Infragistics.Win.UIElementBorderStyle.None;
            DisplayLayout.Override.BorderStyleHeader = Infragistics.Win.UIElementBorderStyle.None;
            DisplayLayout.Override.BorderStyleRow = Infragistics.Win.UIElementBorderStyle.None;
            cellAppearance.BorderColor = System.Drawing.Color.Transparent;
            cellAppearance.FontData.Name = "Microsoft Sans Serif";
            cellAppearance.FontData.SizeInPoints = 8F;
            DisplayLayout.Override.CellAppearance = cellAppearance;
            DisplayLayout.Override.CellClickAction = Infragistics.Win.UltraWinGrid.CellClickAction.RowSelect;
            DisplayLayout.Override.FilterUIType = Infragistics.Win.UltraWinGrid.FilterUIType.FilterRow;
            DisplayLayout.Override.FixedHeaderIndicator = Infragistics.Win.UltraWinGrid.FixedHeaderIndicator.None;
            groupByRowAppearance.BackColor = System.Drawing.Color.LightGray;
            DisplayLayout.Override.GroupByRowAppearance = groupByRowAppearance;
            headerAppearance.BackGradientStyle = Infragistics.Win.GradientStyle.None;
            headerAppearance.FontData.Name = "Microsoft Sans Serif";
            headerAppearance.FontData.SizeInPoints = 8F;
            headerAppearance.ForeColor = System.Drawing.Color.White;
            headerAppearance.ImageBackground = global::CCC.Portal.Common.Properties.Resources.GridHeader;
            headerAppearance.ImageBackgroundStyle = Infragistics.Win.ImageBackgroundStyle.Tiled;
            headerAppearance.TextHAlignAsString = "Left";
            headerAppearance.ThemedElementAlpha = Infragistics.Win.Alpha.Transparent;
            DisplayLayout.Override.HeaderAppearance = headerAppearance;
            DisplayLayout.Override.HeaderClickAction = Infragistics.Win.UltraWinGrid.HeaderClickAction.SortMulti;
            DisplayLayout.Override.HeaderStyle = Infragistics.Win.HeaderStyle.XPThemed;
            rowAlternateAppearance.BackColor = System.Drawing.Color.Gainsboro;
            DisplayLayout.Override.RowAlternateAppearance = rowAlternateAppearance;
            rowAppearance.BorderColor = System.Drawing.Color.Transparent;
            DisplayLayout.Override.RowAppearance = rowAppearance;
            rowSelectorAppearance.BackColor = System.Drawing.Color.White;
            rowSelectorAppearance.ForeColor = System.Drawing.Color.FromArgb(((int)(((byte)(192)))), ((int)(((byte)(0)))), ((int)(((byte)(0)))));
            DisplayLayout.Override.RowSelectorAppearance = rowSelectorAppearance;
            selectedRowAppearance.ImageBackground = global::CCC.Portal.Common.Properties.Resources.HotTrackBackGround;
            selectedRowAppearance.ImageBackgroundStretchMargins = new Infragistics.Win.ImageBackgroundStretchMargins(1, 1, 1, 4);
            selectedRowAppearance.ImageBackgroundStyle = Infragistics.Win.ImageBackgroundStyle.Stretched;
            DisplayLayout.Override.SelectedRowAppearance = selectedRowAppearance;
            DisplayLayout.Override.SummaryDisplayArea = Infragistics.Win.UltraWinGrid.SummaryDisplayAreas.Top;
            scrollBarLookAppearance.ImageBackgroundStretchMargins = new Infragistics.Win.ImageBackgroundStretchMargins(2, 4, 2, 4);
            scrollBarLookAppearance.ImageBackgroundStyle = Infragistics.Win.ImageBackgroundStyle.Stretched;
            scrollBarLook.Appearance = scrollBarLookAppearance;
            scrollBarLook.ViewStyle = Infragistics.Win.UltraWinScrollBar.ScrollBarViewStyle.Outlook2007;
            DisplayLayout.ScrollBarLook = scrollBarLook;
            DisplayLayout.ScrollBounds = Infragistics.Win.UltraWinGrid.ScrollBounds.ScrollToFill;
            DisplayLayout.ScrollStyle = Infragistics.Win.UltraWinGrid.ScrollStyle.Immediate;
            DisplayLayout.UseFixedHeaders = true;
            Font = new System.Drawing.Font("Microsoft Sans Serif", 8.25F);
            UpdateMode = Infragistics.Win.UltraWinGrid.UpdateMode.OnCellChange;
            UseOsThemes = Infragistics.Win.DefaultableBoolean.False;
