I'm using the UltraTimelineView (v10.3) for the first time and trying to set working hours for each owner based on recurrence patterns.
According to the documentation for working hours, 'in the case where more than one recurrence generates an occurrence for the same date, precedence for that date is given to the instance closest to the beginning of the collection.'
Is there some way to override this behaviour? We have recurrences that potentially generate multiple ocurrences on a given date and I need to be able to visualise all of these.
Regards, Jim.
Thanks for your response Brian; I suspected this would be the case, but wanted to be sure there was nothing I had overlooked.
If you are asking if there is a way to have the working hours from each date "merged", the answer is no, that is specifically disallowed because it could create contradictory working hour ranges. For example, the intent for one setting might be to explicitly define a certain time range as non-working hour time, and another setting could make those hours working hours.
