I want to set the splitter width of the separator of the columns in the header of the grid.
When you want to make the width of a column bigger, you go with your mouse between the 2 columns and drags it to make it more width. This separator I want to set the appearance and make it more width.
How do I do that?
Marc
Hi Marc,
marcjannes said:When now the windows themes service is running, you don't see the separator, only your mouse is changing when above. I want to overrule that so that it is always visible.
I'm not sure I understand the issue. But this probably has to do with the HeaderStyle property. You probably need to use a different style. You may also need to set UseOsThemes to false to turn off themes on the grid.
Thanks, I will do.
Do you know how to set this separator, so that it is always seen.
Thanks a lot.
I don't think there is any way to change this. You should Submit a feature request to Infragistics.
