I cannot resolve bug with ultradatetimeeditor:
1) Select section of editor value (for example, select month section) from right to left. Notice, that caret is before section.
2) Type number from keyboard (for example, 12) and result is _2.
I've noticed that when I type first symbol caret change position, but control does not get keydata from keyboard (first symbol was ignored).
How can I set caret position if I want edit date like this way?
Hi Dan,
DanEhrig said:I've just confirmed that this issue is fixed in the 10.3.2067 service release although there is no mention of it in the release notes.
I thought the issue sounded familiar, so I'm not at all surprised that it was fixed.
It probably is mentioned in the release notes, but my guess is that the description probably doesn't mention the exact problem in a way that makes sense to you. The actual bug that was fixed probably says something that seems totally different. :)
Mike, I can confirm that this happens with the release version of Netvantage 10.3 I haven't been able to check for a service release yet.
Please see the attached project. To duplicate the error click-drag on the date field from right to left (not left to right) and highlight it all, then begin typing. It will begin typing in the day field in the middle rather than the month field far left.
Pay no attention to the name of the project/solution, it was originally created to troubleshoot another problem.
I tried this out using the latest service release of NetAdvantage 10.3 and I did not see any problems.But I am having a little trouble understanding what you are describing.
I recommend that you get the latest service release.
If that does not help, perhaps you could post some more specific instructions on how to duplicate the issue. For example, which section are you selecting? Are you using the mouse or the keyboard?
The last (10.3.20103.1000)
