I'm trying to use the Ultrachart, but the label is missing for the last column, and nothing I do seems to get it back.
Hello Chandra123,
I`d like to inform you that I didn`t find a solution of this issue without upgrade of our controls. If you are able please upgrade your products. Let me know if you have any questions.
Regards
Hi Georgi,
We are using ASP.Net 2008 Vol.2, is there any work around to solve this issue without using latest version?
Could you please tell me what is your current version and do you have any installed service release and which one. The mentioned behavior was fixed a few months ago. Right now I made a tests using the latest available versions and everything works properly. I`ll wait your response.
Thanks and Regards
I am facing the same issue with line chart. Could you please suggest me the solution?
Yes, thank you. That worked.
