850
bars do not appear on the Histogram Chart
Hi guys,
I'm trying to display in the ultrachart a set of data, so I decided to use a histogram chart type. I relied on this example
http://help.infragistics.com/Help/NetAdvantage/NET/2008.2/CLR2.0/html/Chart_Working_with_Histogram_Chart_Data.html
That example works fine but when I try with my own data, the bars do not appear only the gauss bell (See attached)
why is this happening?
Is there something that I'm  doing  wrong?
Here is my code
Imports Infragistics.UltraChart.Shared.Styles
Imports Infragistics.Win.UltraWinChart
Imports System.Data.SqlClient
Public Class HistorialChart
    Private Sub HistorialChart_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
        Dim ultraChart1 As New UltraChart
        Me.UltraChart1.ChartType = ChartType.HistogramChart
        Me.UltraChart1.HistogramChart.ColumnAppearance.StringAxis = False
        Me.UltraChart1.HistogramChart.ColumnAppearance.ShowInLegend = True
        Me.UltraChart1.HistogramChart.LineAppearance.DrawStyle = LineDrawStyle.DashDot
        Me.UltraChart1.Axis.X.TickmarkStyle = AxisTickStyle.DataInterval
        Me.UltraChart1.Axis.Y.RangeMin = 0
        Me.UltraChart1.Axis.Y.RangeMax = 20
        Me.UltraChart1.Axis.Y.RangeType = AxisRangeType.Custom
        Me.UltraChart1.Axis.X.Labels.Orientation = TextOrientation.Horizontal
        Me.UltraChart1.Data.DataSource = getValues()
        Me.UltraChart1.Data.DataBind()
    End Sub
    Function getValues() As DataTable
        Dim dt As New DataTable
        dt.Columns.Add("Values", GetType(Double))
        dt.Rows.Add(New Object() {28.78})
        dt.Rows.Add(New Object() {28.71})
        dt.Rows.Add(New Object() {28.97})
        Return dt
    End Function
End Class
  • 26458
    I believe this is happening because you have set TickmarkStyle on the X axis to DataInterval without specifying the actual interval. Actually, in your sample, I would recommend not setting TickmarkStyle property at all. When using the histogram chart, this property is used to set the bucket size.
