920
solution upgrade utility
Doesn't work, errors out with this message:
"xxx.csproj appears to be read-only or not accessible for some reason."
This file is not read-only...the whole project is checked out and not read only.
What is the use of something like this if it won't ever work?
  • 3707
    If you're talking about a upgrading a project that checks out with TFS. Upgrade the project on your machine locally, then check out with TFS.
    Elizabeth from the Infragistics Team answered a similar question here that has more detail: http://forums.infragistics.com/forums/p/53617/277886.aspx#277886
  • 920
    and even if i uncheck read-only on the whole project/solution (which I don't want to do nor think I should have to), I get these two errors from the error log:
    11:20:08: Analyzing CareTracker.Web.UI.csproj...
    11:20:08: The following project needs to have its references updated:
    11:20:08: Could not load the project. Plaese see the Log file for more details.
    11:20:08: startIndex cannot be larger than length of string.
    Parameter name: startIndex
    11:20:08:    at System.String.InternalSubStringWithChecks(Int32 startIndex, Int32 length, Boolean fAlwaysCopy)
       at Infragistics.VersionUtilitySupport.Core.File.Types.WebFile.GetCurrentAssembliesCLR(String assemblyRegisterTag)
       at Infragistics.VersionUtilitySupport.Core.File.Types.WebFile.Analyze()
       at Infragistics.VersionUtilitySupport.Core.File.Types.AdditionalFiles.AddFile(String fileName, Boolean includeCodeBehindFiles, List`1 listOfAssemblies)
       at Infragistics.VersionUtilitySupport.Core.File.Types.ProjectFile.Analyze()
    11:20:23: Upgrading Solution CareTracker.sln
    11:20:23: Updating CareTracker.UI.csproj...
    11:20:23: No matching assembly located in available assemblies Infragistics3.Excel.v10.1
    11:20:23:    at Infragistics.VersionUtilitySupport.Core.ProductAssemblies.AssemblyList.AssemblyNameChange(String assemblyName, Int32 versionLocation, XmlNamespaceManager xmlNamespaceManager, String& assemblyNameNoVersion, Boolean ignoreErrors)
       at Infragistics.VersionUtilitySupport.Core.ProductAssemblies.AssemblyList.FindNewAssemblyNode(String assemblyName)
       at Infragistics.VersionUtilitySupport.Core.File.Types.ProjectFile.Upgrade(String rootDirectory)
