Hi allIs it possible to have different fonts in one UltraLabel ?What I want to do is:The Text of the UltraLabel is: "This is hard a Test"Now I want to have the word "hard" shown as bold,The rest of the text is shown not bold.Thanks and best regardsFrank Uray
Hi Robert,
UltraLabel will not do that. You need to use UltraFormattedLinkLabel - that's the control that supports this kind of formatting.
Hello Georgi,
I found your post searching the web for a possibility to format a portion of the UltraLabel text.In my case, I would like to make a part of the label text bold.I read a post which says that it should be possible using the Infragistics UltraLabel with html formatting, but not how(http://stackoverflow.com/questions/2063263/make-portion-of-a-labels-text-to-be-styled-bold).
I tried something like:
myUltraLabel.Text = "This text is <b>partly</b> bold.";
..but with no success..Could you give me an example how to do it?
Thanks in advance,Robert
Hi GeorgiThanks a lot, this is perfect ! :-)Best regardsFrank Uray
Hello Frank,
I think that it is possible if you use "UltraFormatedLinkLable". Please look the attached example. If you use this component you have a lot of possibilities to change the text (the same like in Word)
Please check the example and send me feedback.
Regards
georgi
