175
Drag and drop highligth appointment
     we are implementing drag and drop from another control to an UltraDayView and we want to highlight the appointment(change bordercolor for example)  that is below the cursor when the user is doing the drag and dropping.
    Any ideas for implementing this feature?
  • 175
    Verified Answer
    finally we found a solution. We implement it with this events:
    Private lastApp As Appointment
       Private Sub UltraDayView1_DragDrop(ByVal sender As Object, ByVal e As System.Windows.Forms.DragEventArgs) Handles UltraDayView1.DragDrop
            Dim _IdPet As Guid = e.Data.GetData(GetType(Guid))
            If _IdPet <> Guid.Empty Then
                MsgBox(_IdPet.ToString)
            End If
            If lastApp IsNot Nothing Then
                lastApp.Appearance.ResetBorderColor()
            End If
        End Sub
        Private Sub UltraDayView1_DragEnter(ByVal sender As Object, ByVal e As System.Windows.Forms.DragEventArgs) Handles UltraDayView1.DragEnter
            e.Effect = DragDropEffects.Copy
        End Sub
        Private Sub UltraDayView1_DragLeave(ByVal sender As Object, ByVal e As System.EventArgs) Handles UltraDayView1.DragLeave
            End If
        End Sub
        Private Sub UltraDayView1_DragOver(ByVal sender As Object, ByVal e As System.Windows.Forms.DragEventArgs) Handles UltraDayView1.DragOver
            End If
            Dim app As Appointment = Nothing
            app = UltraDayView1.GetAppointmentFromPoint(UltraDayView1.PointToClient(New Point(e.X, e.Y)))
            If app IsNot Nothing Then
                app.Appearance.BorderColor = Color.Red
            End If
            lastApp = app
        End Sub
