370
Adding rows in while in CardView
Hi all,
Is there a way to only have  the new row added when I tab out of the CardView add template? I'm not sure if I'm doing anything wrong but right now the new row is added on key down. The moment a key is pressed a new card is added and I can continue editing the new row.
Is this expected behaviour or is there a way to change this so that the row is only added when the user tabs out of  the last field similar to the normal view?
Cheers,
Matei
  • 469350
    Hi Matei,
    This depends on the setting of the AllowAddNew Property. It sounds like you have it set to one of the settings which shows a TemplateAddRow. In that case, as soon as you make a change or type into the TemplateAddRow, the TemplateAddRow becomes an AddRow and a new TemplateAddRow is created.
    I don't think there is any way around this via a property setting. The best you could do is try to detect when this happens and change the AllowAddNew property to turn off the TemplateAddRow. Try using the Before/AfterRowInsert event to turn off the TemplateAddRow. And then maybe use AfterRowUpdate to turn it back on.
