1405
LineChart with TimeAxisStyle of Continuous
Alright,
I'm trying to set up a chart with the following properties:
            Chart.Axis.X.TimeAxisStyle.TimeAxisStyle = RulerGenre.Continuous;
            Chart.Axis.X.TickmarkStyle = AxisTickStyle.Smart;
            Chart.Axis.X.TickmarkIntervalType = AxisIntervalType.Minutes;
            Chart.Axis.X.TickmarkInterval = 1;
My problem is that I do not understand the LineChart well enough to understand how it lays out its data points. Currently I am binding to a dataset with the first column as the series label, and the rest as item labels. I would like your suggestions on how to set up the graph to display as per the above properties with say.. starting at 9am and running until 5pm. I would like to see labels on the x-axis every 15 minutes with the ability to plot data points every minute in between the labels. Can this be done?
Thanks in advance.
