I want to do 3 groups, each group should show subtotals for amount.
the following code, shows subtotal just for the CURRENCY group. But I want to show the CCYAMT subtotals for each of the three groups, and also total summary, for all the data.
basicInfraGrid1.DisplayLayout.Bands[0].SortedColumns.Add("SPOTPORT", false, true); basicInfraGrid1.DisplayLayout.Bands[0].SortedColumns.Add("FIXRATECODE", false, true); basicInfraGrid1.DisplayLayout.Bands[0].SortedColumns.Add("CURRENCY", false, true); SummarySettings st = basicInfraGrid1.DisplayLayout.Bands[0].Summaries.Add(SummaryType.Sum, basicInfraGrid1.DisplayLayout.Bands[0].Columns["CCYAMT"]); st.SummaryDisplayArea = SummaryDisplayAreas.Bottom; st.SummaryPosition = SummaryPosition.UseSummaryPositionColumn;
Just like you added a member to the Summaries collection for the 'CYAMT' column, you would have to add members for the other columns as well. To show a summary column for "all the data", you could add an unbound column which holds the sum total for each column, and add a summary for that column.
