Morning all,
Is it possible to set a group to appear like a drop down btn?
I need to be able to collapse a group when I want to.
uwTBMgr.Ribbon.Tabs(
True
This looks like it might turn the feature on. But I can't find a function to let me set the state to True or False for say: .Collapse = True/False Or a .IsCollapsed check function.
Is this available somewhere and I just can't find it? :)
Deasun
I just wanted to know if you were able to solve your issue based on my suggestions or you still need help? Just let me know.
Thank you.
Hello ,
CanCollapse property indicate whether the group can be collapsed in the ribbon tab displaying only a dropdown button that then displays the group contents. Also you should determine the MinimumSizeOnRibbon and PrefferedSizeOnRibbon of InstanceProps of the tools in the group. Then when there is not enough space to display all tools of the group, it will appear as a popup- menu. Also you could review “Ribbon at Run Time” sample of our “Windows Forms Feature Browser” (usually it is under "C:\Users\Public\Documents\Infragistics\NetAdvantage 2011.2\Windows Forms\Samples ")
