I have an ExplorerBar inside a DockManager. When there is too many items in a group, a scrollbar appears. Is it possible to change the side of the scrollbar depending on the side that the ExplorerBar is docked?
Thank youChris
It's exactly what I was looking for.
Thank you
I am just checking about the progress of this issue. I just wanted to know if you need my further assistance on this issue?
I have modify the sample to work with your latest requirements.
Let me know if you have any further questions.
Sorry for the late response, I had to change my priorities for a while. The proposed solution is working fine for an ExplorerBar using the "ExplorerBar" Style.
Unfortunately, I was looking to use the "OutlookNavigationPane" style (my bad on not mentionning this in my initial post). I will have a look at the link you provided on creation filter and try to follow your example.
I am just checking about the progress of this issue. Let me know If you need my further assistance on this issue?
