Seems like old problem have returned :). Outlook groupby, add one column group, make header border solid. Row selector, first and second columns have non-matching borders, other columns are misaligned with headers (screenshot below). Is there a workaround available for that?
Thank you for the sample. I am seeing the same behavior, so this looks like a bug. I have forwarded this thread over to Infragistics Developer Support so they can look into the issue.
WinForms 2010 vol3 (trial), sample solution attached
What version of the controls are you using?
Can you duplicate this behavior in a small sample project?
