485
Exception while trying to set the visible property of toolbar
 I am using Infragistics 2010 Vol 3.
When i try to set the visible property of the  toolbars item i get an exception.
I have attached the sample application for your reference.
Any workaround for this will be of help.
InfragisticsToolBar2010.zip
  • 290
    Hi Vinutha,
    I looked at your sample app.
    On FormLoad, you are setting,
    ultraToolbarsManager1.Toolbars["ID_NewTool"].Visible = true;
    whereas the Toolbar's Key/Text that exists on the ToolbarsManager is "[UltraToolbar1] - UltraToolbar1"
    and hence you are seeing a 'Key not found' exception.
    Is this the exception that you see or something else?
    Purnima
