108
Get child controls from cursor position
We are having an Ultragrid which displays multiple controls in each cell.
Now the problem is that we need to get information displayed on each controls without entering into edit mode of the cell and then show it as tool tip. Entering the edit mode of a cell on hovering degrades the performance.
  - Is there any way we can get current cursor position within a cell?
  - We also need the control to which the cursor is pointing. so, is there any way to implement this?
A sample program is already attached.
TEST%20APP.zip
  • 69832
    void ultraGrid_MouseHover(object sender, EventArgs e)
        UltraGrid grid = sender as UltraGrid;
        if ( grid == null )
            return;
        Point clientPos = grid.PointToClient(Cursor.Position);
        UIElement controlElement = grid.DisplayLayout.UIElement;
        UIElement elementAtPoint = controlElement.ElementFromPoint(clientPos);
        while ( elementAtPoint != null )
            CellUIElement cellElement = elementAtPoint as CellUIElement;
            if ( cellElement != null )
                Rectangle rect = cellElement.RectInsideBorders;
                Point relativePos = new Point( clientPos.X - rect.Left, clientPos.Y - rect.Top );
            elementAtPoint = elementAtPoint.Parent;
    Assuming you have a reference to the user control that contains the controls for which you want to hit test, you can use the Control.GetChildAtPoint method.
