903
Removing the rootlocation in rootlocation's locations dropdown
I need to "hide" or remove the Rootlocation from the rootlocation's locations dropdown showing the navigationBar.RootLocation.Locations' collection
I don't find any property to remove it from the dropdown, is this possible ?
  • 48586
    I just wanted to know if you were able to solve your issue based on my latest suggestions or you still need help? Just let me know.
    Thank you.
  • 48586
    Suggested Answer
    Hello ,
    Location object of UltraNavigationBar has a property called DisplayText, that determines string which is displayed in NavigationBar. For example you could use code like :
    this.ultraNavigationBar1.RootLocation.DisplayText = "HideText";
    this.ultraNavigationBar1.RootLocation.Text = "C:";
    or when you add location to the RootLocation you could use:
    UltraNavigationBarLocation lok = ultraNavigationBar1.RootLocation.Locations.Add("5", "test1");
    lok.DisplayText = "Your Text Here";
    On the following link you could find and tutorial how to use UltraNavigationBar, and how to populate its locations.
    http://help.infragistics.com/Help/NetAdvantage/WinForms/2010.2/CLR2.0/html/WinNavigationBar_Browsing_the_File_System_with_WinNavigationBar.html
    let me know if you have any further questions.
