Dear support,here is my problem.
I'm using Visual Studio 2008 (.Net 2.0) and Infragistics NetAdvantage 2008 vol .1 (WinForms) on a Windows Xp SP2 PC.
Create a new Winform Application (WindowsFormApplication1) with Visual Studio.The Form1 is the main form of the application.At design time change the property Form1.IsMdiContainer to true.Add an UltraToolbarsManager controls to Form1, then press SHOW RIBBON.Start the application (WindowsFormApplication1) with form1 in WindowsState=normal (not maximized).
Now open Microsoft Windows Explorer in normal mode (not maximized, not minimized) and move it to partially overlap the WindowsFormApplication1.Set the focus (with a mouse click) to WindowsFormApplication1.Set the focus (with a mouse click) to Microsoft Windows Explorer.
The Microsoft windows Explorer is not redrawed in the overlapped region and the WindowsFormApplication1 seems yet in front position.
Why?
Thank you.
Luca Minerva
The latest public hotfix should fix the issue for all versions 7.1 and up. You can get the details for downloading this fix here:
http://blogs.infragistics.com/blogs/vmcdonald/archive/2008/04/23/public-hot-fix-released-netadvantage-for-net-april-23-2008.aspx
We are using 7.3 and we are seeing this problem. Is there a fix for 7.3 or the fix is only avail on version 8?
I figured that would be the case. I submitted my bug earlier along with my system configuration and steps to reproduce. I hope that gets me into the private hotfix party....thanks for letting me know.
-Ken
The fix will be in the next private hotfix. I believe it is scheduled to be released next friday, but I think you will have to submit the issue to the support group to be able to download the hotfix: http://es.infragistics.com/gethelp. If not, I would recommend submitting it anyway so you can be notified when it is released.
Is this fixed in the latest release? or is it coming out as a HotFix?
I still see the problem (all the time) in 2008.1
thanks
