Dear Mike,
The below is the sample data for a histogram chart. When I use Excel and create a histogram chart , the output is as like in the second picture, but When I use the same data and if i create histogram chart in Ultrawinchart, the output is like in the third picture,
We need the exact output that was created using the excel.For this requirements, What are the condition or properties that should be set for a histogram chart? Kindly please do reply as at the earliest possible.
Hello Sureshsimkumar,
Have you been able to resolve your issue ? Did you have a time to take a look at the attached sample. Please let me know if you have any questions.
Regards
Maybe one possible approach to achieve the desired behavior is by using Composite Chart with two layers. The first one will be ColumnType and second one will be LineType. Could you please take a look at the attached sample for more details. Please let me know if you have any questions.
