I am using piechart 3D in my application. I have usede the tool tip for both the chart and for the legend. The format that i have used for chart is
assetAllocationChart.ToolTipFormat =
"<ITEM_LABEL>" + "(" + "<PERCENT_VALUE:#,#0.00>%)" + "(" + "<DATA_VALUE:#,#,0.00>" + ")";
and for tooltip is
this
.ultraChart1.Legend.FormatString = "<ITEM_LABEL>" + "(" + "<PERCENT_VALUE:#0.00>%" + ")"
this.ultraChart1.Tooltips.FormatString = "<ITEM_LABEL>" + "(" + "<PERCENT_VALUE:#0.00>%)" + "(" + "<DATA_VALUE:#,#,0.00>" + ")";
The problem is, when i mouse over different slices of pie chart, the tooltip is updated correctly for each slices but for legend only the ITEM_LABEL and DATA_VALUE is updated. The percent_value is same as the last percent value of the legend item.
I don know why it's happenening.
This issue appears to have been fixed. Please make sure you're using the latest service release for your version of NetAdvantage.
