I am using VS2005 and netAdvantage 2004 V3. I would like to get the NetAdvantage controls to show in the VS Toolbox but can't seem to figure out how. I read Article: KB04884 but in says to chose 'Customize Toolbox' from the context menu. I don't get that option in my menu. I checked in other places and can not find a similar option.
So any help would be appreciated.
Gary
Thanks, I also found that there is a menu Item under Tools/Choose Toolbox Items that does the same thing.
Thanks again.
1.) Right click the toolbox and select "Add Tab" presuming you haven't already done this.
2.) Give it the new Tab a name.
3.) The new Tab's area should show "There are no usable controls in this group. Drag an item onto this text to add it to the toolbox."
4.) Right click in the new Tab and select "Choose Items"
5.) You will want to select the items from the ".NET Framework Components" Tab. It helps if you do a single click on the "Namespace" Column Header to sort them asc, scroll down to the Infragistic.xx section and then place a check in the ones you would like to add.
I don't have VS2005 installed to confirm my suspicion, but it appears to me that the article is wrong. I believe you need to select "Choose Items..." from the context menu, rather than 'Customize Toolbox'.
