150
UltraDayView Drag Appointment Error
I am currently having some troubles and some mixed results on calendar controls. Currently I have a calendarInfo control bound to a bindingsource which is a custom object that has some of the appointed bound properties but not all. I have an ultraDayView control with the datasource set to the calendarInfo control. When I try to move the appointment more than a 15 minute increment it throws an Index was outside the bounds of the array error.
I think it may have something to do with the say I have mapped my object to the calendarInfo so I am attacking that piece of code.
Mapping Code:
Private Sub SetCalAppointmentBindings()
calInfo.DataBindingsForAppointments.DataSource =
Nothing
calInfo.DataBindingsForAppointments.DataSource = bsTask
calInfo.DataBindingsForAppointments.BindingContextControl = Me
calInfo.DataBindingsForAppointments.SubjectMember =
"TaskName"
calInfo.DataBindingsForAppointments.DescriptionMember = "TaskDescription"
calInfo.DataBindingsForAppointments.StartDateTimeMember = "DueDate"
calInfo.DataBindingsForAppointments.EndDateTimeMember = "EndDate"
calInfo.DataBindingsForAppointments.OwnerKeyMember = "SalesRepID"
calInfo.DataBindingsForAppointments.DataKeyMember = "DataKeyMember"
 End Sub
Here is the error and stack trace:
Index was outside the bounds of the array.
Error type: System.IndexOutOfRangeException
Source of error (stack trace):
Infragistics.Win.UltraWinSchedule.UltraDayView.EnsurePrimaryAppointmentIsFirst(Object[]& selectedAppts, Appointment primaryAppointment)
Infragistics.Win.UltraWinSchedule.UltraDayView.DragAppointmentsToTimeSlot(MouseMessageInfo msginfo)
Infragistics.Win.UltraWinSchedule.UltraDayView.DragAppointments(MouseMessageInfo msginfo)
Infragistics.Win.UltraWinSchedule.UltraDayView.Infragistics.Win.ISelectionManager.OnDragMove(MouseMessageInfo& msginfo)
Infragistics.Win.SelectionStrategyBase.DragMove(MouseMessageInfo msgInfo)
Infragistics.Win.SelectionStrategyExtended.OnMouseMove(ISelectableItem item, MouseMessageInfo& msginfo)
Infragistics.Win.SelectionStrategyExtended.OnMouseMessage(ISelectableItem item, MouseMessageInfo& msginfo)
Infragistics.Win.ControlUIElementBase.ProcessMouseMoveHelper(Object sender, MouseEventArgs e)
Infragistics.Win.ControlUIElementBase.ProcessMouseMove(Object sender, MouseEventArgs e)
Infragistics.Win.Utilities.ProcessEvent(Control control, ProcessEvent eventToProcess, EventArgs e)
Infragistics.Win.UltraControlBase.OnMouseMove(MouseEventArgs e)
System.Windows.Forms.Control.WmMouseMove(Message& m)
System.Windows.Forms.Control.WndProc(Message& m)
System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
System.Windows.Forms.NativeWindow.DebuggableCallback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
System.Windows.Forms.UnsafeNativeMethods.DispatchMessageW(MSG& msg)
System.Windows.Forms.Application.ComponentManager.System.Windows.Forms.UnsafeNativeMethods.IMsoComponentManager.FPushMessageLoop(IntPtr dwComponentID, Int32 reason, Int32 pvLoopData)
System.Windows.Forms.Application.ThreadContext.RunMessageLoopInner(Int32 reason, ApplicationContext context)
System.Windows.Forms.Application.ThreadContext.RunMessageLoop(Int32 reason, ApplicationContext context)
System.Windows.Forms.Application.RunDialog(Form form)
System.Windows.Forms.Form.ShowDialog(IWin32Window owner)
System.Windows.Forms.Form.ShowDialog()
CxUi5.fMain.OpenDialog(Type FormType, fBase Opener, Object[] Args) in D:\Development\CxUi5\CxUi5\Base Forms\fMain.vb:line 39
Any help would be great and I am sure additional info is needed.
