Navigation panes collapsed with each other. The problem is, i have designed my form on one screen resolution, and on my form i am showing left and right both navigation panes with pin property set to as True for both the panes. I have adjusted the panes in such a way that their is no space between them.
Now on run time, if i change my screen resolution things go worst, if i increase the resolution i can a dead space between the panes, and if i decrease the space, the panes start collapsing, and one pane come over second. Any suggestion how to overcome this problem, no matter what the screen resolution is
Regards:
iMi
Assign a value to the threshold that is dependent on the local machine's screen resolution. You can get that from the Screen class.
