In the documentation (see the link bellow) there is written, that:"For assemblies with both CLR2 and CLR 3 versions (like Infragistics2.Excel.v10.2 and Infragistics3.Excel.v10.2), the version -free assemblies will match the latest CLR version. So the version-free Excel assembly will be Infragistics.Excel.dll and is the one built for the CLR3 version."
http://help.infragistics.com/Help/NetAdvantage/WinForms/2010.3/CLR2.0/html/Introduction_About_Version-Free_Assemblies.html
But this is not true:
In the directory Version-Free (20102_WinForms_VersionFree.zip) there is used Infragistics.Excel.dll in zip file which is built on the CLR2 and not on CLR3. (same as Infragistics2.Excel.v10.2.dll)
In the directory Version-Free - Signed (20102_WinForms_VersionFree_Signed.zip) there is used Infragistics.Excel.dll which is built on the CLR2 and not on CLR3 too.
Infragistics.Win.UltraWinGrid.ExcelExport.dll has a same problem.
And our problem is that when we try to export an excel file in format for Office 2007, we receive an error
"packageFactory cannot be null. When saving to Excel2007 workbook format and using the Infragistics2.Excel assembly, you must provide an IPackageFactory to handle the packaging of data. If you are using the DotNet Framework 3.0 or higher, use the Infragistics3.Excel assembly instead, and the packaging will be handled by the WindowsBase class"
But there are not version-free CLR3 versions of those dll-s.
Can somebody help me with that.
I have an answer from support.
It's necessary to download latest service release. Checked in latest service release version of 10.2. and it looks OK.
Check this link
http://forums.infragistics.com/forums/t/51701.aspx
I'm having the exact same problem. I need the version-free CLR3 version of Infragistics.Excel.dll
