2715
UltraGrid cell mask issue
Hi!
I have a ultragrid, and in one of its cells i've set up a mask, like this :
UltraGridColumn column = ulgPricesBudget.DisplayLayout.Bands[0].Columns["FY"];
            column.MaskInput = "20##";
            column.MaskDataMode = MaskMode.IncludeBoth;
            column.MaskDisplayMode = MaskMode.IncludeBoth;
In the BeforeExitEditMode I do a check :
if (ulgPricesBudget.ActiveCell.Column.Key == "FY" && ulgPricesBudget.ActiveCell.EditorResolved.Value.ToString() != "") { .....  }
So the mask is like this "20__" - it's an year.
This is the code line that throws an exception if i insert in the masked cell a value like "20_1" (i insert just the last character the "1"). The exception is :
Internal error: can't get masked editor value. Inner exception is: Input does not match the mask.
What am i doing wrong ?
Could you help me in this issue ?
Thanks!
