I have a UltraOptionSetEditorColumn inside a DataGridView. The ValueListitem for the UltraOptionSetEditorColumn has 3 posibble vaules. The UltraOptionSetEditorColumn looks OK, but when I tried to click on the UltraOptionSetEditorColumn cell, I got an error: Operation is not valid because it results in a reentrant call to the SetCurrentCellAddressCore function.
I can't find any example about UltraOptionSetEditorColumn . if I use UltraComboEditorColumn, everything works fine, but the user wants the radioButton look.
Please help!
Thanks!
Amy
Amy,
I have logged this as a development issue.
Hi Amy,
I don't have a SQl Server to test this with, so I used an UltraDataSource instead and I now see the error you are getting. I'm going to forward this over to Infragistics Developer Support so they can check it out.
yamao said:BTW, how can I get the selected radio button value?
You would use the Value property of the cell in the grid.
Hi Mike ,
it is pretty easy to produce. I can't send dev solution, since it is too big. I attached a test project to demo the problem.
To use the example, please create a database in your Sql server, the database name is test. I attached the table creation and insert scripts. If you set the GridView MultipleSelect to false, the exception will occur.
Thanks!Amy
I've never heard of that error message before. Can you post a small sample project demonstrating the error so I can check it out?
Or, if that's not possible, posting the entire call stack of the exception might help.
