990
Column order in ultratree
Hi!
I use UltraTree v 10.3 to show hierarchical data. I populate the tree with a dataset et at each level, the columns order is the primary key and the significant column after. So in my tree, the nodes showed are the pk values because the tree show the first column. How can I show another column of the datatable instead of the first one.
I tried to make column visible = false in the ColumnSetGenerated event but it doesn't work. I also tried to put autoGeneratedColumns to false and configure it myself but it is complicated and it doesn't not work very good. Any ideas ?
I can't order my query to have the desired column first so I have to manage this problem with the ultra tree.
Best regards,
Benoit
