new to this so this question will probably be simple to answer.
I have a ultrawingrid that I would like to copy and paste a row from wthin the wingrid.
So basically
take a selected row in the grid. copy and paste into the row beneath.
Thanks in advance
Thanks Mike
Paul
Check out the AllowMultiCellOperation property on the grid.DisplayLayout.Override.
Also, if you want to do this in code using a button, then you will use the PerformMultiCellOperation method on the grid.
Sorry, I should also mention this is to work by a button click event and in c#
