620
Color of the specific rows not changing.
I am trying to change the color of the rows whose ID is less than 5. But this is not working. I am trying to use the NorthWind Dataset. Can anyone help in finding the problem.
Here is the code:
namespace Sample_UltraGrid
    public partial class Form1 : Form
        public Form1()
            InitializeComponent();
        private void Form1_Load(object sender, EventArgs e)
            this.ordersTableAdapter.Fill(this.nwindDataSet.Orders);
        private void ultraGrid1_InitializeLayout(object sender, Infragistics.Win.UltraWinGrid.InitializeLayoutEventArgs e)
            // Create an appearance for values which are less than 5
            Infragistics.Win.Appearance lessThan = e.Layout.Appearances.Add("Less");
            lessThan.ForeColor = Color.Red;
            // Create an appearance for values which are greater than 5
            Infragistics.Win.Appearance greaterThan = e.Layout.Appearances.Add("Greater");
            greaterThan.ForeColor = Color.Green;
        private void ultraGrid1_InitializeRow(object sender, InitializeRowEventArgs e)
            UltraGrid grid = (UltraGrid)sender;
            // Get the value of the EmployeeID column.
            UltraGridColumn employeeIDColumn = this.ultraGrid1.DisplayLayout.Bands[0].Columns["EmployeeID"];
            int ID = (int)e.Row.GetCellValue(employeeIDColumn);
            if (ID < 5)
                // Use the Negative Appearance already defined in the grid's Appearances collection.
                e.Row.Cells["EmployeeID"].Appearance = grid.DisplayLayout.Appearances["Less"];
            else
                // Use the Positive Appearance already defined in the grid's Appearances collection.
                e.Row.Cells["EmployeeID"].Appearance = grid.DisplayLayout.Appearances["Greater"];
