I am using Infragistics WinSchedule 7.1.20071.40 (base).
I seem to be having an issue with the MonthViewSingle control where the scrollbar that is displayed (because of setting OwnerNavigationStyle to DropDownAndScrollbar) is disabled, even after multiple Owners have been added to the UltraCalendarInfo object and the OwnerDisplayStyle is set to Separate.
Under what scenarios is this scrollbar disabled?
Is there a bug fix that I do not know about?
The same issue was expressed in this post on your old forum system: http://forums.archive.infragistics.com/readmessage?id=%3C75852733$1cff24cd$192f9c@news.infragistics.com%3E&group=infragistics.products.netadvantage.windowsforms.winschedule
Any help would be appreciated.
I really do not have the option of getting the latest version since the latest version that is compatible with .NET 1.1 is 7.1 (which is what I am using).
Is there any way that I can avoid coming across this bug? Perhaps doing something a little differently in my code? Even if you could point me to a place in the Infragistics source code that I could study.
Thanks.
Yes, that is a bug that has since been fixed. You should download the latest version.
