490
Reusing Appearance object
I am getting an error of "Key already exists" when trying to reuse an appearance object with the UltraGrid.  Here is the scenario:
1. In the grid's Initialize_Layout method I have the following code to set up my appearance:
// cancel date appearance
if (!this.ugCommon.DisplayLayout.Appearances.Exists(CANCEL_DATE))
Infragistics.Win.Appearance cancelDateAppearance = this.ugCommon.DisplayLayout.Appearances.Add(CANCEL_DATE);
cancelDateAppearance.ForeColor = Color.Red;
2. My grid has a column called "Cancel Date".  If today's date is greater than this value then I need to make the text of the entire row red.  To do this I added some code to the InitializeRow event.  I compare the dates and if I have to add the red coloring I am doing this:
foreach (UltraGridCell c in e.Row.Cells)
c.SelectedAppearance = this.ugCommon.DisplayLayout.Appearances[CANCEL_DATE];
c.Appearance = this.ugCommon.DisplayLayout.Appearances[CANCEL_DATE]; <== Problem Line of Code
The error occurs on the second line in the foreach loop:
I am not sure what is going on here.  I have to make sure both the appearance and the selected appearance have red text, so I need to change both.
