I have an UltraWinExplorerBar on my project. When I click on UltraExplorerBar designer... a form pops up behind my current VS window(I can see it in aero preview) but It looks empty and I can't open it.
During this time my main Visual Studio window is nonresponsive.
Once I close the second window visual studio behaves normally. Basically, its like the designer is trying to open but encountering an error.
Please help me solve this issue.
I'm running windows 7 64 bit right now with Infragistics Netadvantage for WinForms 2010.2 and Visual Studio 2010 and Team Foundation with a VSS server.
Hello Johannes,
Thank you for your feedback.
I am glad that you are able to solve your issue.
OK problem solved.
I work on a laptop with a second monitor. My laptop monitor was disabled and the second monitor was my primary display.
I switched back to my laptop as the primary display and the second monitor as the secondary display. The popup showed up almost out of sight.
So my theory is that the designer was opening up out of range of the screen.
I went 1 step further. I uninstalled infragistics 10.2 and reinstalled. Then I deleted and readded all the references and did a clean build. Nothing changed. I still cannot open the window.
I even created a brand new project, added the control, and then attempted to open the designer and I couldn't. The window appears not to be fully loading.
In the aero preview I can see that a window is there but I can't open it.
My suggestion is to delete all Infragistics’s reference, then add them again , clean the project, clean the licenses file, close all open windows and rebuild the project. Please follow this steps and let me know for the result.
I am looking forward to get your details.
