330
Sorting in ultragrid string column.
Hi all,
  I have ultragrid column named Rank, it has value range from 1-10 and default value as *. So we made the column datatype as string instead of numeric just to allow default value as "*". If the column has *,4,5,10. if we sort by ascending it display as *,10,4,5. but the expected result is *,4,5,10.
How to achieve this?
* has to considered as 0.
i am using the following code for sorting.
UltraGridColumn selectedColumn = SelectedColumns.FirstOrDefault();
UltraGridBand  band = bgFMEA.DisplayLayout.Bands[0];
band.SortedColumns.Clear();
band.SortedColumns.Add(selectedColumn.Key, false);
selectedColumn.SortIndicator = SortIndicator.Ascending;
Thanks in advance
Regards
Vijay A
