80
Decimals in edit mode.
Hi All,
Here is my problem. I have a UltraDataGrid that is bound to a datasource (that gets populated from DB). One of the columns is of type Decimal. I need to format the value to only have 2 decimals. (No problem there just set the format for the column). My problem is that when the cell goes into edit more it show a lot more decimals. It goes from 2.45 to 2.4499999999..
So the question how can I change the display format in edit mode so it only shows 2 decimals (or possible 4 since that is used in the back end)
