330
Word Wrap and Truncation in UltraGrid Header
 I am adding dynamic column to ultragrid. I have set the Width and height as below.
bgCandE.DisplayLayout.Override.DefaultRowHeight = 50;
bgCandE.DisplayLayout.Override.DefaultColWidth = 200;
and enable word wrapping and truncation using the below code in the
ultragrid InitializeLayout event.
ugCol.CellMultiLine =
DefaultableBoolean.True;
ugCol.Band.Columns[ugCol.Key].CellMultiLine =
1) Word Wrapping and truncation is not happening for Column Header.How to achieve word wrapping and truncation in the dynamic column header.
2) For the above set column height and width ,it display three rows and truncation happens. If value in the cell is small whcih fits for the only one line,it always displays height of three rows but i want don't want to display the blank row in the cell.
   If it has value for one row,then only one row has to be displayed which no blank row.If it has the value for two rows,then two rows has to be displayed which no blank row. if it has three or more rows,truncation should happen and display three rows only.
  How to achieve this.
Thanks in advance
Regards
Vijay A
