280
How to re-enable rowedittemplate when grid datasource is changed?
Hi all,
In my application I have a single ultragrid. I want to perform different input functions with the grid by changing the data source/member and loading a different saved layout.
I want to do the input to a row edit template.
When I change the datasource on the grid, the row edit template is disabled and is not re-enabled when I set the datasource and layout back to the original
At runtime, how can I re-enable the row edit template.
Roger
