35
Problem while adding ultrawingrid to the form
Hi
I am using visual studio 10.0 and infragistic 8.2, when I have create a new solution, now i have added a ultrawingrid to the form it build the project it give me error "Code generation for property 'ViewStyleBand' failed.  Error was: 'Type 'Infragistics.Win.UltraWinGrid.ViewStyleBand' is not available in the target framework.' " Previously it was working fine I have reinstall window-7 and install visual studio 10.0 and then infragistic 8.2, but when I opened and existing project in vs 10.0 it work fine.
Can you help me what should be the problem?
Rajneesh Kumar
  • 435
    unfortunately VS2010 often sets the Framework to .NET Framework 4.0 Client Profile if you create a new solution.
    Maybe you just have to set the Framework for your Project to .NET Framework 4.0 (not Client Profile).
    Let me hear if this helped you.
    EDIT: Ah, someone was faster ;)
  • 71886
    Hello Rajneesh,
    I believe that you could find an answer in the following forum thread:
    http://forums.infragistics.com/forums/t/56094.aspx
    Mike Saltzman explains possible reasons for this to happen.
    Please do not hesitate to ask if something comes up.
