I have added a Ribbon Tab "Home", "Tools" and "Help". Inside each tab i have many groups. The requirement is that i need to add that tools that is present in "Tools" Tab to the Quick Access Toolbar only not the tools from "Home" and "Help". Office2007UICompatibility is set to false. When they right-click i want to disable "Add to Quick Access Toolbar" for the tools that is present in the "Home" and "Help" tab. In the "BeforeToolbarListDropdown" event is there an option to check which tab does the tool belong to? Please help me out?
Rajagopalan.
Hi Rajagopalan,
To get the ribbonTab the tool belongs to you can check the owner property of the tool. If this is a ribbonGroup you can get RibbonTab from it. This can be done using the following piece of code:
private void ultraToolbarsManager1_BeforeToolbarListDropdown(object sender, BeforeToolbarListDropdownEventArgs e)
ToolBase tool = e.Tool;
if (tool != null)
Object owner = tool.Owner;
RibbonGroup group = owner as RibbonGroup;
if (group != null)
RibbonTab tab = group.Tab;
// Check for tab.Caption property and place the desired logic here}
Vaibhav
