185
AfterColPosChanged
The AfterColPosChanged event fires for each record in a grid when using the Infragistics.Win.UltraWinGrid.DocumentExport to print a PDF of the records in the grid.  So, when executing the following code, the AfterColPosChanged event fires for each record in the grid:
Private Sub cmdPDFForms_Click(ByVal sender As Object, ByVal e As System.EventArgs) Handles cmdPDFForms.Click
Me.SaveFileDialog.AddExtension = True
Me.SaveFileDialog.DefaultExt =
".pdf"
Me
.SaveFileDialog.ShowDialog()
If SaveFileDialog.FileName <> ""
Then
Me.UltraGridDocumentExporter1.Export(Me.ugForms, Me.SaveFileDialog.FileName, Infragistics.Win.UltraWinGrid.DocumentExport.GridExportFileFormat
.PDF)
End
If
End Sub
This problem does not occur using the Excel exporter or PrintDocument.  Those behave as expected.
