25
UltraWinGrid and multiple grouping
Hi all,
we are having reproducible problem with UltraWinGrid version 10.1.20101.2027. The easiest to reproduce is to bind collection of simple objects with few properties to wingrid and then try to group by several columns. It does not work as expected.
Additionally if other columns are removed and just one original column stays in group by of the grid then the result in grid is much different to original when group by is setup from scratch
1. 1 column in group by
2.  2 columns in groupd by
3. Again 1 column and result is different than in step 1).
Do you know a workaround how to fix it?
RSV
Prototype-ErrorWhenGrouppingByMoreThanOneColumn.zip
