415
Infragistics.Excel.Workbook.Load(Template) Generating Error on 64-Bit OS/Office
Attempting to export grid data on Win7 64-Bit with Office 2010 64-bit generates the following error:
Index was out of range. It must be non-negative and less than the size of the collection.
Parameter name: index
Actual value was 0., Exporting to file = 'C:\Users\Administrator\AppData\Local\Temp\Customers_5AB5.tmp'; Using template = 'C:\Program Files (x86)\Sage Software\Sage MAS 500 Client\GridTemplates\empty.xlsx'; Excel file format = 'Unknown'.
   at Infragistics.Excel.WorksheetCollection.get_Item(Int32 index)
   at Infragistics.Excel.Workbook.OnAfterLoadGlobalSettings(WorkbookSerializationManager manager)
   at Infragistics.Excel.Serialization.Excel2007.XLSX.Elements.WorkbookElement.OnAfterLoadChildElements(Excel2007WorkbookSerializationManager manager, ElementDataCache elementCache)
   at Infragistics.Excel.Serialization.Excel2007.XmlElementBase.LoadChildElements(Excel2007WorkbookSerializationManager manager, ExcelXmlNode node, ExcelXmlDocument document, XmlReader reader, ElementDataCache elementCache, List`1 elementCacheCollection, BeforeLoadElementCallback beforeLoadElementHandler, AfterLoadElementCallback afterLoadElementHandler, Boolean& isReaderOnNextNode)
   at Infragistics.Excel.Serialization.Excel2007.XmlElementBase.LoadChildElements(Excel2007WorkbookSerializationManager manager, ExcelXmlNode node, BeforeLoadElementCallback beforeLoadElementHandler, AfterLoadElementCallback afterLoadElementHandler, Boolean& isReaderOnNextNode)
   at Infragistics.Excel.Serialization.Excel2007.XmlContentTypeBase.Load(Excel2007WorkbookSerializationManager manager, Stream contentTypeStream)
   at Infragistics.Excel.Serialization.Excel2007.Excel2007WorkbookSerializationManager.LoadPart(IPackagePart part)
   at Infragistics.Excel.Serialization.Excel2007.Excel2007WorkbookSerializationManager.LoadPartRelationships(IEnumerable`1 relationships, ContentTypeBase contentType)
   at Infragistics.Excel.Serialization.Excel2007.Excel2007WorkbookSerializationManager.LoadWorkbookContents()
   at Infragistics.Excel.Serialization.WorkbookSerializationManager.Load()
   at Infragistics.Excel.Workbook.LoadXLSXFile(Workbook workbook, Stream stream, IPackageFactory packageFactory, Boolean verifyExcel2007Xml)
   at Infragistics.Excel.Workbook.LoadHelper(Stream stream, WorkbookFormat format, String parameterName, IPackageFactory packageFactory, Boolean verifyExcel2007Xml)
   at Infragistics.Excel.Workbook.Load(String fileName, IPackageFactory packageFactory, Boolean verifyExcel2007Xml)
The excel file is 2010 file format, a workbook with three blank sheets.
