I have a grid and in the grid there is a column with dropdown. I define in the code like:
this.grid.DisplayLayout.Bands[0].Columns["columnName"].AutoCompleteMode = Infragistics.Win.AutoCompleteMode.Suggest;
this.grid.DisplayLayout.Bands[0].Columns["columnName"].FilterOperatorDropDownItems = FilterOperatorDropDownItems.Contains;
the name of the column is correct and when i try to write a name of the value that im looking for it just jumps directly trough the values that start with the letters that i input.
eg. if i try to write "ST James Hospital" , when i press "S" it goes to ST James Hospital , but when i press the "T" it goes to another item that starts with "T" like Talbot lodge.
It sounds like your column is set to DropDownList style, which means you cannot type into the edit portion of the cell - the user can only choose items from the list. Try setting the column's Style to DropDown.
i'm working with netadvantage winforms .net 2008 vol. 3 CLR 2.0
