85
UltraGridAction.AboveCell Moves LEFT and UltraGridAction.BelowCell Moves RIGHT
I'm trapping the _KeyDown event on an UltraGrid with the following code:
private void ucDataGridComponent_KeyDown(object sender, KeyEventArgs e)
            switch (e.KeyCode)
                case Keys.Up:
                    this.PerformAction(UltraGridAction.ExitEditMode, false, false);
                    this.PerformAction(UltraGridAction.AboveCell, false, false);
                    e.Handled = true;
                    this.PerformAction(UltraGridAction.EnterEditMode, false, false);
                    break;
                case Keys.Down:
                    this.PerformAction(UltraGridAction.BelowCell, false, false);
                    e.Handled = true;
                    break;
                case Keys.Right:
                    this.PerformAction(UltraGridAction.NextCellByTab, false, false);
                    e.Handled = true;
                    break;
                case Keys.Left:
                    this.PerformAction(UltraGridAction.PrevCellByTab, false, false);
                    e.Handled = true;
                    break;
However, Key Down always goes LEFT and Key Up always goes RIGHT.  Can someone tell me why?
  • 5
    I've found a workaround to this problem.  By the way, it has not been fixed in Netadvantage 2008 2.0
    Linda Jaeger
    jaegerl@transcontinental.ca
    Private Sub UltraGrid1_KeyDown(ByVal sender As Object, ByVal e As System.Windows.Forms.KeyEventArgs) Handles UltraGrid1.KeyDown
    Select Case e.KeyCode
    Case Keys.Up
    Me.UltraGrid1.PerformAction(UltraGridAction.ExitEditMode, False, False)
    Dim save_active_cell_index As Integer = Me.UltraGrid1.ActiveCell.Column.Index
    If Me.UltraGrid1.ActiveRow.Index > 0 Then
    Me.UltraGrid1.ActiveRow = Me.UltraGrid1.Rows(Me.UltraGrid1.ActiveRow.Index - 1)
    Me.UltraGrid1.ActiveCell = Me.UltraGrid1.ActiveRow.Cells(save_active_cell_index)
    End If
    e.Handled = True
    Me.UltraGrid1.PerformAction(UltraGridAction.EnterEditMode, False, False)
    Case Keys.Down
    If Me.UltraGrid1.ActiveRow.Index < Me.UltraGrid1.Rows.Count Then
    Me.UltraGrid1.ActiveRow = Me.UltraGrid1.Rows(Me.UltraGrid1.ActiveRow.Index + 1)
    End If
    e.Handled = True
    Case Keys.Right
    Me.UltraGrid1.PerformAction(UltraGridAction.NextCellByTab, False, False)
    e.Handled = True
    Case Keys.Left
    Me.UltraGrid1.PerformAction(UltraGridAction.PrevCellByTab, False, False)
    e.Handled = True
    End Select
