I use TimeLineView control, set timeslot interval to 1 day, the calender info mindate and max date to 1 month (from 01/10/2010 to 31/10/2010)
I use this code to add an Appointment to date 01/01/2010 in form_load event, but it not work:
private void Form_Load(object sender, EventArgs e) { this.ultraTimelineView1.EnsureDateTimeVisible(this.ultraCalendarInfo1.MinDate); ultraCalendarInfo1.Owners.Add("100", "Pham Nhu Chung"); ultraCalendarInfo1.Appointments.Add(new DateTime( 2010,10,01),new DateTime( 2010,10,01), "TEST");
}but when i replace last line code to (add Appoitment to date 02/10/2010) ultraCalendarInfo1.Appointments.Add(new DateTime( 2010,10,02),new DateTime( 2010,10,02), "TEST"); then it worksThanks.
where is the bug tracker Can I follow? can you show me the link?
This is a bug in the control; thank you bringing it to our attention. It will be fixed in a forthcoming service release; refer to bug ID 58741.
Note that in the meantime, you can work around this issue by making the appointment's duration non-zero, i.e., specify a value for 'endDateTime' that is at least one minute greater than that of 'startDateTime'
