Within the Quick Access Toolbar is there is a way of giving users the ability to change the ordering of the tools without removing them and adding them again? In Office if you right click on the toolbar you have the "Customize Quick Access Toolbar .." option which lets you do this.
I understand I could probably override the drop down menu and write my own option but wondered if there was easy way!
Andy
Sorry for the late reply! Thanks for your help, i've finally got round to looking into this and have been able to achieve what I needed to.
Cheers,
I am just checking about the progress of this issue. Did you solve your issue accordingly to the information that I provided you?
Let me know if you need any further assistance.
Hello Andrew,
I have researched your scenario more deeply and found two similar discussion in the forums. You can find this forum threads helpful customizing QAT of UltraToolbarsManager:
http://forums.infragistics.com/forums/p/20067/183873.aspx
http://community.infragistics.com/forums/t/43562.aspx
Let me know if this is working for your scenario or if you have any further question.
